In reply to a message from Doug Dwyer sent Fri 17 Jul 2009:
My temperature gage starts as the bottom and slowly moves up to a
point where the top of the needle is a bit below the N, and that is
where is typically stays around town.
Had in on the road to Jacksonville and back, about 1-1/2 hour trip
each way, and it would work its way up to where the needle was
centered in the N, then up to where the top of the needle was at
the top of the N.
However, when I got off I-95 and into traffic setting at a red
light, the gage went up to where the bottom of the needle was just
barely above the top of the N. After driving in traffic awhile, the
needle came back down to where the top of the needle was just below
the top of the N. After a couple of stops parking in shade, the
needle came back down to the bottom of the N and a little below the
N.
About 6-9 months ago when it overheated and I had to replace both
thermostats the needle went most of the way up.
Mine definitely does not have any steps - varies with temperature
all the way.
My oil pressure gage varies all the way too. As stated in another
post above, warm/hot idle is around 10 psi and goes up from there.–
The temp gauge isn’t an on-off fixed reading like the oil pressure gauges
but it is heavily dampened. The service manual says ‘‘The temperature gauge
is calibrated to give a ‘normal’ reading over a wide range of temperatures.’’
175�F to 230�F results in the needle staying fixed on the ‘‘N’’.
Jerry Peck, 83XJS/past-54XK140,54MKVII,59MK,60MKII,67E,72XJ6
Ormond Beach, FL, United States
