I need the name of a good mechanic in Orange County, NY.–
BRIANV
BRIANV
In reply to a message from BRIANV sent Sat 28 Mar 2009:
Hi, yours will be a Marelli ignition one I think (dizzy with
two centre electridodes, one offset) and a common failure is
flywheel and crank sensors. Ohm them, by memory should be
approx 700 Ohms. If you cannot find a Jag mechanic locally
good FIAT or Lancia mechanics may be an idea, alternatively
BMW mech who has worked on V12s.–
PEXJC
