I need to replace the alternator on my 85 XJS and I am asking about
my options, have mine rebuilt, buy rebuilt, or is there an
alternative such as Bosc
thanks, Bob–
GTPAPA
In reply to a message from GTPAPA sent Fri 27 Jan 2012:
Hi there,
I have been using a 95amp Bosch alternator on
on my 1974 Lump for the last 5 years without any problems.
It is a little different with the wiring at the back of the
alternator but nothing that any auto electrician can’t handle
in a few minutes. Good luck…Haroldus–
I bought a bracket and 94 amp altenator from John’s cars for my 85.
It was a very simple install and it works great.–
Mike Blair 94 6.0coupe+85 XJS, 96XJ12, 60MkIX, XJ13replica
powhatan/Va, United States
In reply to a message from eyedoc sent Fri 27 Jan 2012:
The alternator on my '96 VDP crapped out in November. I picked up a
direct replacement rebuild at Advance and so far so good.–
Roger’95
In reply to a message from Roger’95 sent Fri 27 Jan 2012:
Hi there,
Everybody’s happy. That’s a welcome change…Haroldus…–
thanks, Bob–
Whatever you do, make sure that the replacement alternator is at
least one-hundred amp–Lucas alternators of that vintage are anemic
at best putting out somewhere around 80 amps. Terrible. I know this
is not encouraging, BUT you may be able to find a real old-time
shop that can rewind your alternator and install the diode packs,
etc while at the same time uprating the alternators capability. I
lived with a Lucas alternator on my old XJ6 for many years swearing
at it the whole time.
The Bosch unit will not fit BUT if you have a clever mechanic who
you trust, I think a mount could be fabricated. I have seen it done
on other cars. Also, you might think of posting a request for any
info anyone might have about switching to a GM Delco alternator
(good, cheap and generally reliable) . . .that would include info
on how to get or make a new mount.
