A bit of history first: bought my XJ-S in 2003 with only 14k
miles. In 2005 and with around 20k miles on the clock I
found this:
http://www.jag-lovers.org/snaps/snap_view.php3?id=1131124826
that I could not believe for a car with so little miles on
it. I mentioned this photo album link a couple of months ago
when a poster was in doubt if removing the radiator. Maybe
you might think: Luis lives in a 3rd world country, with
very dirty streets and roads. Well yes, we have many unpaved
and dirty roads here, but that is NOT the territory where I
walk my cat. I do it on roads that would not differ much in
cleanliness from what I find when I travel in Europe or the
USA. Besides, searching the photo albums I’ve seen I’m not
the only one here:
http://www.jag-lovers.org/snaps/snap_view.php3?id=1188704175
Nowadays I have 33k on the clock, have been driving the car
for some 10 days after a VERY long siesta of several months.
It is summer here, not strange to have days over 30�C and
even 35�C (mid 90�F). No overheating at all, but it seemed
strange to me that after a drive of only 15 minutes the
electrical fan kept on for several minutes. I did not recall
that to be normal. I also remembered that the coolant was
more the 5 years old, so decided to change it. Following my
own advice, I removed the radiator too. This is what I found
after about 12k miles of the previous pictures:
http://www.jag-lovers.org/v.htm?1328962511
AMAZING! All that dirt hidden behind a perfectly clean oil
radiator and A/C condenser. It is obvious that the dirt does
NOT come from impacts at speed, but is sucked when the car
is standing still with the engine on. No air by-passes the
radiator thanks to foam against the fan shroud. But much air
by-passes the oil cooler and A/C condenser. There is a gap
in between of them, and also a gap to the sides of them and
below the oil cooler. From below is where most of the dirt
and fluff comes from, not because the gap is bigger, but
because it’s where most of the dirt is to be found: on the
floor. Besides, the right side (of the car) is where most of
the dirt is to be found, because it’s where the big fan is.
I’m trying the ‘solution’ with a metallic mosquito net you
can see in the pictures. No idea if it’ll work. Pictures are
from Friday and car hasn’t been driven yet. But I recommend
everybody: if in doubt, remove the radiator!! Especially if
you have a healthy fan clutch or strong electric fans.
Rgds, Luis.–
Luis Gasperini / '91 V12 XJ-S conv. 5sp
Montevideo, Uruguay
