Hi Paul,
Everything is at the left front component panel, under the bonnet. The
fuse is fuse #4, 15A, in that fuse panel, and the fan relay is the
forwardmost relay in that panel (~ 5 relays, total).
If you want to read along on the circuit diagram, (it’s really not that
hard to follow with a little practice and someone leading you through
it) go to this site and download the Electrical Guide for your 95 4.0L
and to fig. 24, Auxiliary Cooling Fan:
http://www.captainjaguarscathouse.com/Electrical_Reference.htm
Pull the relay off its base and carefully examine the underside of the
relay, next to the pins, for pin numbers: 30, 85, 86 & 87. Now examine
the relay base, and you should find that there are Brown/Green wires
going to pin sockets 86 & 87, a Black/Green wire going to pin socket
30, and a Green/Brown wire going to pin 85. The “Brown/Green” wires
are predominantly Brown, with a Green stripe or tracer, and the
“Green/Brown” wire is predominantly Green with a Brown stripe. Make
sure you note the difference, and make sure the relay pins, as
numbered, go in the sockets with the wire colors as indicated. If NOT,
check back with me BEFORE you do any of the following tests.
Once you have become familiar with the wires attached to the relay
base, and have identified each as the colors indicated above, do the
following tests (with the relay out of the base for tests 1, 2 & 3):
(1) using your voltmeter, selecting a range greater than 12V, put the
red probe on socket 87 (Brown/Green wire) and black probe on ground.
You should get 12V+, battery power (key does not need to be on).
(2) do the same voltmeter test on socket 86, and the result should be
the same.
(3) if you have battery power in each of the tests above, apply a
jumper (just a piece of plain wire) between sockets 87 and 30; the fan
should run.
(4) replace the relay in its base; apply a ground to the Black wire in
the base, and the fan should run. If you don’t have test jumper wires
(available cheap from Harbor Freight) with alligator clips, you can
just use a piece of plain wire with one end anchored to ground (good
metal or bolt on engine).
If all those tests went as described, your fan works and your relay
works. The switch is either on or off; it does NOT change resistance
with temperature like the CTS or temp gauge sender. When it is on
(contacts closed/making contact) it completes a ground to pin 85 of the
relay (Black wire) just like you did manually in test 4. Basically, if
all 4 tests went as described, if your fan is not running, the switch
is NOT closing and providing ground to pin 85.
89 and 85 XJ-S Coupes; 89 XJ40 VDP-----Original Message-----
I checked the fuse and it is O.K. I found my multimeter (was in
my boot - phew!) and would like to test the relay with it. Any
idea how to do that?
If the relay is O.K., how do I use the multimeter to check the
thermo switch? Should the resistance across it change as the
coolant heats up?
