Hello everyone!
Last time I posted about a/c I hoped it would be the last
time for several years, but it was not to be.
My cars a/c has been done to death (I know y’all have
heard this litany from me before) with 3 compressors, a
new parallel flow condenser, aftermarket pusher fans in
front of the condenser to keep it cool , 4 or more driers
and expansion valves, new valve stems, new mechanical fan
clutch and new foam around the radiator and the condenser
to help with air flow…but always back to square one.
System would be great after having work done and then
start getting worse. 3 independent Jaguar places looked at
her. They all tried dye and sniffers. In the end, it seems
like the car is loosing a very very small amount of r 134
over time. Never to where it’s been empty, but enough for
me to feel a difference in the Texas heat.
My Jaguar mechanic tried everything he could to eliminate
the evaporator…he watched those drains for dye, tried
to place the sniffer thru ongodly places on the car, but
no go. The evaporator is all that’s left. Added to that
the fact that I have been hearing noises (like Darth Vader
talking) from behind the dash, it is all that is left to
do.
My evaporator was ‘‘supposedly’’ replaced 3 or 4 years ago.
Because of issues with that particular shop and because I
never saw my dash in a million parts, I am pretty sure it
was never done.
So the evaporator is being replaced today, new drier and
exp valve as well of course. The crumbling foam that comes
out from the vents into my eyes will be replaced as well,
and the clips that hold the defroster vents in place so my
window won’t condense at night.
This better take care of it for good.
The part is aluminum because that is all we could find for
the 95:96 cars, but I have been told they are made of a
higher quality now to prevent future leaks. I have also
been told to replace the drier every often (2 years) to
make sure moisture does not eat out the evaporator from
inside out.
BTW if anyone knows how much oil needs to be added to the
system after both the evaporator and the drier are
replaced, please post it. My mechanic is pretty good, but
I want to make sure I stay on top of things.–
95 AJ16 http://www.jag-lovers.org/v.htm?1325653847 Houston
Houston, TX, United States
