In reply to a message from Veekay sent Sun 29 Mar 2015:
On this engine and car, no !
On other critters, out and in situ, yes.
Room for the BFH is essential. Room for prying or a slide
hammer is essential.
Next is a clean block for the new plug to seat properly,
and as such seal.
Then, the room thing again, to drive the plug home. More
BFH and a suitable driver.
Or, a tad of a block sealer, the crystal type.
Way back when, a similar issue occurred on my 58 Pontiac
Star Chief. a small plug at the rear of the head on the
left bank. Should’ve removed the head. Not all that bad a
task.
But, nope, I drilled a series of small holes as a method of
making an access opening. Worked, a slide hammer pulled
out the one with the hole. Enough room to drive hoe an new
plug. A sheet metal patch secured the hole and all was
well, til the next issue…
Carl
Carl–
The ‘‘cylinder block core plug’’, part number C168623 is
leaking by my exhaust manifold. Not a lot, but enough to
annoy me.
Carl Hutchins 1983 Jaguar XJ6 with LT1 and 1994 Jeep Grand
Walnut Creek, California, United States
