In reply to a message from RCielec sent Wed 3 Feb 2016:
RC (name)
If you get the serial number off the radio you can contact
Jaguar USA and they might still have the codes, I tried
two different used radios (Alpine Cr*p) that died fast. So
went with the Pioneer DHE-12E looks good and not too
flashy. I like having a front loading CD player.
It has the power to antenna line (B/W) and ran that through
a switch on the lower left panel, the dummy switch next to
Emergency flasher. with a little work you can use the
switch from the fog lamps in that spot!
I tried to post photos but my server will not let that
happen, I can send photos off line.
Dan–
- How does one solve the unknown security code issue with
2)For those of you who have replaced the original radios- I did not find the procedure to circumvent the auto-
DanS
columbus ga. usa, United States
