In reply to a message from MGuar sent Thu 6 Jan 2011:
Yada Yada Yada - for those interested in some factual stuff:
Energy content (High and low heating value)
A plastic container used widely for storing gasoline.Gasoline
contains about 35 MJ/L (9.7 kW�h/L, 132 MJ/US gal, 36.6 kWh/US gal)
(higher heating value) or 13 kWh/kg. This is an average; gasoline
blends differ, and therefore actual energy content varies from
season to season and from batch to batch, by up to 4% more or less
than the average, according to the US EPA. On average, about 19.5
US gallons (16.2 imp gal; 74 L) of gasoline are available from a 42-
US-gallon (35 imp gal; 160 L) barrel of crude oil (about 46% by
volume), varying due to quality of crude and grade of gasoline. The
remaining residue comes off as products ranging from tar to naptha.
[9]
Volumetric and mass energy density of some fuels compared with
gasoline (in the rows with gross and net, they are from [10]):
Fuel type[clarification needed] Gross MJ/L MJ/kg Gross BTU/gal
(imp) Gross BTU/gal
(U.S.) Net BTU/gal (U.S.) RON
Conventional gasoline 34.8 44.4[11] 150,100 125,000 115,400
Autogas (LPG) (60% Propane + 40% Butane)[citation needed] 26.8
46 108
Ethanol 21.2[11] 26.8[11] 101,600 84,600 75,700 113[12]
Methanol 17.9 19.9[11] 77,600 64,600 56,600 123
Butanol[2] 29.2 36.6 91-99[clarification needed]
Gasohol 31.2 145,200 120,900 112,400 93/94[clarification needed]
Diesel(*) 38.6 45.4 166,600 138,700 128,700 25
Biodiesel 33.3-35.7 [13][clarification needed] 126,200 117,100
Avgas (high octane gasoline) 33.5 46.8 144,400 120,200 112,000
Jet fuel (kerosene based) 35.1 43.8 151,242 125,935
Jet fuel (naphtha) 127,500 118,700
Liquefied natural gas 25.3 ~55 109,000 90,800
Liquefied petroleum gas 91,300 83,500
Hydrogen 10.1 (at 20 kelvins) 142 130[14]
(*) Diesel fuel is not used in a gasoline engine, so its low octane
rating is not an issue; the relevant metric for diesel engines is
the cetane number–
lockheed 92 XJS Cpe/97 LT1 Miami FL/ 96 XJS Cv 4.0 Austin TX
Austin, TX, United States
