In reply to a message from Gene Holtzclaw sent Sat 14 Sep 2013:
Gene,
I would think that the 2 twisted wires as a single conductor and
using the outer shielding as the second conductor is still
problematic as the distance between the twisted wires and the outer
shielding varies greatly and would not have a fixed ohm value
consistency as would a 50 ohm coax.
The '89 schematic shows the signal wiring between the power amps
and the PCMI (ECU) to be regular wiring and not coax or twisted
pair - just plain two wires. It is true that the later versions
did upgrade to coax between the PCMI and the power amps. As far as
I can see, the signal from the PCMI to the Lucas EFI ECU has always
been coax with a single conductor and the outer shielding is
grounded.–
lockheed 92 XJS Cpe/97 LT1 Miami FL/ 96 XJS Cv 4.0 Austin TX
Austin, TX, United States
