Hi Gene,
You are doing Great!. Now that you can hook up the scope and see
something, we can now get down to business.
First step: Hook the scope up to the sensors open circuit and get a
reading from both. This is done by just looking at the sensors with
no leads coming off of them at all.
Note: I don’t know how you are recording the scope data but what you
want to do is note the scope setting on amplitude/voltage and in
conjunction note the actual voltage you are reading. You can write
this down or send the data from the scope to some recording device
such as a computer. I believe.
In reply to a message from mike90 sent Sat 14 Sep 2013:
… I put it on the rear sensor (flywheel), and I can get a
reading on the scope, and then I move to the ECU, and get what
appears to be the SAME reading at pins 3 and 16. However, the
signal I’m getting looks nothing like what is shown on page 18.2-5
Fig 1.
This change in the signal integrity is a factor of two things, the
load/terminus and the transmission medium. Do the open ckt test
above and we can go from there.
I move to the front sensor, and I get a much lessor signal, and
even then, only on one wire, whereas I get a signal on BOTH wires
on the rear sensor. I don’t know if the front sensor is bad, or???
The signal is shown for the front signal on page 18.2-4 Fig 1. Not
touching the ocsilloscope, I don’t get a signal like I do from the
rear. It is very faint at best. And this is only on one wire.
Once again, the signal at the ECU is a function of the load/terminus
and the mode of transmission. Two separate causes. Once again, do
the open ckt test stated above and we can go from there. Oh, whether
you get a signal across two wires or one wire is a function of the
setup of the sensor ground and the transmission medium ground.
I feel that I am doing something very wrong. Both sensors appear
new and if you don’t want to read back through, my rear sensor was
at .045 from the flywheel, but I fixed that, and got it to .024.
So far you have done nothing wrong but discovered that … Hey,
Yeah! Looks like there is a function of signal integrity/fidelity in
going from the sensor and transmitting that signal, intact back to
the ECU.
89 XJS convertible Marelli ignition
Ptipon
Sonora/CA 90 V12 conv, USA
// please trim quoted text to context onlyOn Sep 14, 2013, at 12:09 PM, Gene Holtzclaw wrote:
