In reply to a message from Kirbert sent Mon 9 Sep 2013:
Wow, you guys, in addition to Gene, have been busy! I could not
have a look at the progress on this thread on Sunday until this
Monday morning.
I might mention that one of the problems Gene is facing, too, with
his harness, is that the color codes on the wires may, or may not,
match up with the schematics (that is, there are times when the
color codes match, and there are times when they do not). That is
why I asked him to buzz out each pin on the Marelli ECU connector
to where it lands on the engine.
One other thing: people have been mentioning, on and off, that
evidently there was a problem with this car before all of this
harness stuff was done, likely in an attempt to address whatever
this problem was. I agree on this. What, exactly, the problem
was, is as yet, unknown, but we clearly have an ignition problem
now. Gene will see what else lurks once he can get fire
consistently.
But, what I am trying to get to is this: the harness Gene has
consists of what appears to be a later Marelli harness, grafted
into the original '89 harness. So, what does this mean, exactly?
It means, among other things, that the connectors to key components
(ECU, amps, coils, temperature sensor, specifically) are probably
the ones that were on the original harness…see where I am going?
I am wondering about the integrity of the connectors as regards the
B bank circuit.
However, Gene’s use of an analog VOM to try to ascertain where the
pulse train is being lost appears to show that the signal is being
lost at the ECU…this makes me come back to a ground problem. Or,
a pin/wire problem AT the ECU connector itself.
Gene: can you post the serial number or the numbers you find on
that ECU? As I recall, you will have a series that are
stamped/etched into the diecasting, and there will also be a series
in paint. I have two ECUs, one in the car, and another I have from
an '89 parts car I bought when I was returning my car to operating
condition over ten years ago, now, and I will get those numbers,
and maybe we can hazard a guess as to when/what series your ECU
belongs.
I can tell you this: Gene’s ECU functions fine as regards starting,
idling and throttling my 1990, so I do not think the ECU is at
fault.
-Mike–
Mike, 1990 5.3 XJS Conv., 5-speed, SE-ECU, TT Extractors
Lakewood, OH, United States
