In reply to a message from CJ95 sent Thu 29 Aug 2013:
John:
Yes, the results are useable indeed. What I meant to say, more
precisely, is that the problem did not switch banks when the amps
or the coils were swapped. This vindicated both the amps and coils.
It’s a bit hasty to point to the ECU next, at least on this car,
and this is because it has a transplanted ignition harness. Yes,
you heard correctly: this is not the original harness.
That is why I have been stepping through this harness very
carefully with Gene. He’s got the S-57 wiring schematics and the
rest of the Marelli documentation I pulled from the shop manuals.
And we’ve stepped through this pretty carefully.
Never-the-less, the testing and inspection done thus far have
convinced Gene and I that the ECU must be at fault.
Your point on Gene checking the firing by looking at the coil wires
is excellent- when I first discussed the idea of the rotor
advancing away, he quickly informed me that he was looking at the
coil wire behavior. So this nixed the distributor argument. I
still like this, which is why I mentioned it earlier (even though
it can’t possibly be acting in this case, at least at this point in
the game).
Again, we are pointing back to the ECU.
Lockheed: your comment on teeth on the flywheel is well taken.
When I converted my car to a 5 speed, I had to fit the Marelli
sensor to the bell, and I did this by using a die grinder to notch
the bell for the sensor element itself, and then I created a flat
surface on the periphery of the housing for the mounting flange and
then drilling and tapping to mount the sensor. I was worried about
clearance with the teeth, and had read Bywater’s ‘unfussy’
clearance comment and specification. Never-the-less, I mounted
this sensor such that the clearance was at the far end of the
range. Guess what happened? When the car got warmed up (and the
bell housing expanded) the engine quit. When I got it home, the
next morning, it fired right up. I knew then that the speed sensor
gap had to be adjusted. I changed the clearance to be mid-spec,
and since that time, it’s run flawlessly.
Fun.
-M–
Any result is usable. What happened to the spark when the
Mike, 1990 5.3 XJS Conv., 5-speed, SE-ECU, TT Extractors
Lakewood, OH, United States
