In reply to a message from mike90 sent Fri 30 Aug 2013:
Mike,
You made a statement that brings me in line with your logic. I can
recall that many have said that the V12 will not start or run if
the front crank sensor is faulty or disconnected. I don’t recall
that anyone had definitively said the same about the rear flywheel
sensor, until you clarified the point by stating that your engine
flat out quit when warm, and the gap at the rear sensor became too
great - resulting in the loss of the rear sensor signal to the
ECU. That settled it - the fault is probably not with the rear
sensor signal since there are some sparks. With regard to the
other musing about why Jaguar set the trigger fingers at 8 deg.
past TDC, it could be to eliminate the initial starting knock that
sometimes occurs in engines with some amount of advance timing at
start, and the slow revolution of the engine cranked by the
starter. But, nearly any engine will run with a surprising amount
of retarded (ATDC) timing if the spark is there. I (and I’m sure
some others) have inadvertently installed a distributor or two
retarded by a tooth or two, and the engine ran, but was a real dog -
and why won’t this engine run if there is no problem with the
sparks on A bank - maybe the drag of the dead B bank and not enough
throttle opening? Oh well, press on with the current plan of
attack.–
lockheed 92 XJS Cpe/97 LT1 Miami FL/ 96 XJS Cv 4.0 Austin TX
Austin, TX, United States
