Unless you’ve added some new temp sensors for your OBDII reader, it
only has 2 to choose from: (1) temp gauge sender (single spade), or (2)
CTS (Coolant Temperature Sensor for EMS which has two spades). It
probably uses the CTS output to the EMS. Both of these sensors have a
resistance that varies with engine temperature at the thermostat
housing where they are mounted. If whichever of those sensors it uses
(or its wiring) is bad, the Reader temperature number will be bad.
So if you want to confirm the readings, don’t measure anything at the
radiator (where temperature varies ~ 30 degrees from top to bottom, but
measure at the thermostat housing where the sensor is located.
Now we are back to what I suggested days ago, which is measure
thermostat housing temps with an infrared thermometer, temp gauge
resistance with ohm meter and record corresponding gauge position for
temps between 190 & 220F. Get data from a number of people with
facelift cars, and you have something reliable to use (assuming a
specific method is adopted for use by all participants so ALL the
readings are obtained in the same fashion).
All you’ve done with the OBDII reader is add a new variable (which
you’re having to confirm with an infrared thermometer). You don’t even
know what sensor output you are measuring unless you pull the connector
to each alternatively and see when the temp readout stops. The
software of the Reader has to convert the resistance to a temperature.
What’s the number of degrees variation from actual in that software
conversion?
Technology is great, but unless you understand what it is really doing,
it can simply be bells & whistles, giving data that you assume is a
certain thing, and accurate, when it may be relying on a defective
sensor or wiring in the vehicle, and giving an entirely different data
point from what you assumed, which is inaccurate.
89 and 85 XJ-S Coupes; 89 XJ40 VDP-----Original Message-----
Alright, I had a wireless OBDII reader (works over
Bluetooth)…
I will drive to work tomorrow with the AC on and see what it
reads. I will borrow an IR temp gun and see if I get a
similar reading from the radiator.
