Can’t find where the back connection goes to. Any ideas?–
Alan
Sierra Vista, United States
Alan
I’m not sure which hose you are referring to, or what the “back
connection” is, so I will describe each of the three hoses in the
system and what they connect.
(1) High Pressure Hose goes from the power steering pump (hose fitting
as opposed to hose clamp) to the pinion tower of the steering rack;
(2) Return hose (A) goes from the pinion tower of the steering rack to
the P/S fluid cooler on the left side of the subframe;
(3) Return hose (B) goes from the fluid cooler to the power steering
pump.
Hose #3 is all rubber. Hoses 1 & 2 have rubber sections and steel tube
sections.
89 and 85 XJ-S Coupes; 89 XJ40 VDP-----Original Message-----
