Hello all you XJS lovers, I have just bought my first, a
renoverings object.
can someone tell me where the Relay to passenger side el window
sits/is situated on 1988 V12 HE ?
My drivers side door has dropped: Can someone tell me how to fix
that problem please.
best regards to all.
Andrew in Sweden.–
andrewgradin
renoverings object.
There is a relay behind the trim on the outboard side of the foot well.
Not sure if it’s for the window motor or the lock solenoid.
Could it be wear in the hinge pins? Grab the door at the open edge
and see if it moves when you lift. If it does it’s probably the hinge pins.
If it seems pretty solid, but just riding too low, it could be that
someone had it off at one time and failed to set it right
when reinstalling it.
I have replaced the hinge pins with a GM part, requiring reaming out the
holes. I can provide more info if you decide to do that.
In reply to a message from Ed Sowell sent Thu 31 Mar 2005:
Hello Ed, Thank You sir. will look again at the door tomorrow
and.get back to you about Hinge pins.
andrew–
andrewgradin
On my '88 (USA, LHD) the power window relay is mounted on the right side
component panel below/behind the glove box. It’ll be a round relay with
brown/blue, white/pink, and black wires.
If yours is faulty it can be replaced with a garden variety 30 amp
automotive relay with the “30-85-86-87” terminal designations and
configuration.
There is also a thermal breaker in the circuit.
Doug Dwyer
Longview, Washington USA
1987 Ser III XJ6
1988 XJS V12
