I have 96 XJS. I was experiencing a common problem with
the passenger rear quarter glass motor on occasion. A
couple of taps with a long screwdriver and everything went
back to normal.
I decided to take it apart yesterday and I don’t think I
found good news, but I’m not a motor expert so I need some
feedback.
As you can see in the first two pictures, the commutator
has a definitive area where it has been rubbed down. The
magnets have been making direct contact with the
commutator and I believe that is the source of my
problems. I don’t think there’s a way to prevent this
from happening on my motor.
The third photo shows a clean motor housing. I didn’t do
anything to it, this was the condition it was in when I
opened it up.
The rest of the photos shows what everything looked like
after I cleaned it up with a wire brush. I lined
everything up with some silicone paste and it’s back in
the car now.
The question is did I fix anything?
I did flip the magnets around so that the worn areas are
now at the other end of the housing, opposite of where the
commutator shows contact. That should at least reset the
inevitable wearing down again, no?
http://www.jag-lovers.org/v.htm?1463258409--
1996 XJS 2+2 Convertible with 4.0L AJ16
