I do not disagree with your statements. I did not say there were no
performance differences, just that they are minor.
Speaking only on modern Jaguars, the difference is neglibible. For example,
the HP rating on a Euro XJR? 400. Whats the US rating? 390. I don’t see a
significant difference here.
The older V12s do see more of a noticable increase, but the 6 cylinders in
the US are all post 92 and they all have a US HP rating of around 240, and
are pretty peppy. Its generally agreed that removing exhaust restrictions on
a typical car and opening up the intakes will gain you no more than a 10-15%
increase in power, and in a very heavy car, it is almost unnoticable.
Call me a environmentalist but I just dont see a need to remove the
emissions controls on a 6 cylinder XJS unless being used for racing , and it
was my impression the questioner did not have that in mind. For race
applications the differences are much more noticable. Id say leave
everything in place unless the catalytic converters are bad in which case
gut them.
Daniel
1994 XJ12
1995 XJS 4.0----- Original Message -----
To: xj-s@jag-lovers.org
Sent: Friday, November 05, 2004 12:34 PM
Subject: Re: [xj-s] XJS’95: Differences European vs US models
In reply to a message from beke001 sent Fri 5 Nov 2004:
I stand corrected. I didn’t realize it is every other year. Also,
it is a good point about other issues not being figured into an
emissions test, like suspension, frame, etc. On the flip side,
California cars are desired due to the favorable climate. The body
and frame of a California car will usually be in much better shape
than say an Ohio car like mine where they love using enough salt on
the roads to turn Lake Erie into the Dead Sea.
Most likely today all US cars are the same, but in years past,
there were different systems installed for California cars.
As to not having reduced performance, I respectfully disagree. I
have a friend in Canada with several ‘‘Canadian Market’’ Jags,
several with V12’s, and they don’t have all the pollution control
plumbing, they came with higher compression engines than the US
cars, and are a bit quicker. At least speaking of the late 80’s,
early 90’s cars, the US market got the most ‘‘de-tuned’’ of the group.
There is also a reason why folks who modify cars for racetrack use
remove all emissions systems, to gain horsepower. Anytime your
engine has to do anything in addidtion to transferring power to the
wheels, that is power NOT going to the wheels.
My Canadian friend also states, and I trust his information, that
the cars for the European market were the most powerful, moreso
even than the Canadian cars. He has one with a European market
engine and he says it runs circles around his other V12’s. I am
using his info since I have only owned and driven one V12 car in my
life, the one I bought, so I really have nothing to compare it to.
Just my two bits.
Tom, 89 XJS Coupe
Reynoldsburg Ohio, United States
