In reply to a message from Doug Dwyer sent Sun 27 Mar 2005:
I have to agree with Doug here. About
seven months ago, I went bottom fishing and
picked up an 85 XJ6 S3 on the cheap.
The car had a tremendous amount of
deferred maintenance and needed repairs,
however the body and interior were in
reasonable shape (no rust). Just to give
you an idea of what I have done so far
to get it into shape as a daily driver:
- New belts and hoses
- Coolant flush and rad re-core
- New (used) fuel tanks
- New fuel rail
- New injector hoses and clamps
- Injectors cleaned
- New rear calipers and pads
- New front catalytic converter
- New oil,trannie and fuel filters
- New fluids
- New plugs, wires, cap, rotor
- Misc rubber parts (still ongoing)
- New heater valve
- New valve cover gaskets and end plugs
- Misc. tinkering to get things running
correctly
- New (used) air pump
- New tires
- New lower ball joint (yes, one only)
- New steering rack bushings
- Front end alignment
- New fuel pump
- New thermostat
- New (used) Air Flow Meter
- New O2 sensor
- New misc. gaskets
Surprisingly, parts are plentiful and
rather inexpensive compared to other British
cars I’ve owned…provided one takes
the time to shop around.
I still have an a/c compressor to replace
and I want to re-shoot the body at some
point, but for now I enjoy just driving
the car. We just returned from an 800 mile
trip along Oregon state’s coastline without
incident. It was my first real reliability
test since undertaking the work above, and
I have no complaints to report other than
the choices of music I had to endure.
So far, the only time the car failed me was
when the fuel pump when gunny sack in the
parking lot of my neighborhood post office.
This occured just after I purchased the
car. It was a pretty easy and quick fix.
The radiator really did not need to be
re-cored, however it is one of those
jobs I believe should be done on
general principals for any 20 year old
British car. It is just good insurance.
The bottoms of the fuel tanks were
swiss-cheese due to rust and I purchased
two used, rust free tanks from a California
car for US$100.00 delivered to Seattle.
The above may seem like a lot of work,
however I now have a baseline established to
undertake further work and help in the
diagnosis of future issues. The work above
was completed while driving the car on
a somewhat regular basis. Downtime was
usually limited to waiting for parts
to be delivered andtheir installation.
It IS a wonderful machine to drive and
makes very comfortable and IMHO an
inexpensive daily driver.
Good Luck!
Best Regards,
Kirk Yonker
Seattle
81 Triumph TR8 dhc fi
85 Jaguar XJ6 S3–
Wedgepig
