In view of the higher-than-desirable temperatures in my 1990 V12 last week
(recap: after 3 hours highway driving the temperature would go to 95+ with
AC on. Cutting the AC lowered the temps a bit. Crossing into Canada
immediately brought the temp. to 88-90. I can either keep this car at home,
or try to resolve the problem), I have spent the day replacing thermostats,
which were new and newly installed, and yes, correctly. I am using the usual
82 degree (usual here for the V12, that is) OEM Waxstats. I am still waiting
for one thermostat, but I have removed the two that were in there. I tested
both in a pan with a thermometer (my wife is away; but if the next spaghetti
sauce tastes a bit like antifreeze, I am in trouble).
Here is my question: I assume that an 82 degree thermostat should open
fully at 82 degrees, and not simply begin to open at that temperature. Is
this correct? If so, I had two faulty thermostats (yes, they were marked
“82”); they were not fully open until the water temperature approached 95,
and they did not even begin to open until close to that temperature. This
now has me wondering. Have I now installed an untested (new) 82 degree
thermostat that may also be faulty? The one I get tomorrow will be tested
before installation. Opinions please
And Frank-the-mechanic has okayed the use of Water Wetter in this
engine; he was in fact quite positive and felt that it would have no effect
on any Barr’s Leak that might be in the system (my only concern). So I will
do that, and I will report. The car is being driven to Seattle for a second
concours event on Friday, and the ambient temperatures are supposed to be in
the 30’s (90’s for Americans).
Gregory===================================================
