Hello XJ6 Aficionados,
Sigh. Well, there has been this weird knocking sound
emanating from the 1987 XJ6 series III after it warms up
since I purchased it 2 months ago. At first we thought it
was the engine. Fortunately, the tappet guards are there
and we think we have ruled that out. But today we looked
underneath the XJ6 and noticed two big holes that must be
for stoneguards (see photos in link below) in the
transmission. You can see the torque converter spinning
through the open holes when the car is running, which is
disconcerting.
So, I flipped through the parts manual and saw the Borg
Warner appears to have only one stoneguard hole at the
bottom, instead of two. So, can anyone recognize what type
of transmission this might be with 2 holes? I’m guessing
it needs some stoneguards but without knowing the type,
ordering those parts might be tricky. Not having the
service records for the vehicle is less than desirable!
As for the noise, in case anyone has any ideas, it is
rhythmic and its speed is tied to the RPMs. When a load is
put on it is duller and when the load off you can still
hear it but it is clanky. So, today it seemed like the
noise might be emanating from closer to the torque
converter area. After doing some internet research, I
think the most likely candidate might be a loose flywheel,
but open to suggestions!
Here is my list of things to do for the XJ6:
- Resolve knocking sound
- Fix exhaust leak near exhaust manifold
- Drain the gas tanks (and find a gas tank plug for the
side that is missing one) - Figure out why wipers work on high but no other speed and
won’t park - Cruise control (bought a new bellow but the old one looks
fine) - Replace a few bushings once the new poly kit arrives
- Window are slowwwww (hopefully just cleaning solenoids)
- Passenger rear door lock attached uselessly
- Passenger front door won’t unlock with the rest of the
auto lock/unlock - Minor paint touchups
- Minor driver’s seat repair before it gets worse
- The left side passenger door light comes on only when
driver side door open…
Looks like a busy summer!
- Ginger–
Garage: 1987 XJ6 Series III
