In reply to a message from uncoded sent Fri 9 Oct 2009:
Got to be a little careful here because UK manifolds and vac
routing are different (among themselves, as well) but if there’s a
pipe on the underneath at the back, pointing straight down, it’s
the drain. Cap it with a short length of tube and block the end.
You definitely need a non-return valve in the line that goes to the
bulkhead.
See SKJagtech’s diagram : http://tinyurl.com/5f7ka9
Doesn’t show the nrv but gives a clue about pipe routings.–
understand in Alex’s diagram though. I am still unsure what
the spigot under the intake manifold should be connected to.
His diagram has a ‘‘one way valve’’ in the line from ‘‘delay’’
to ‘‘delanaire AC’’ I don’t remember seeing one on my car,
just the valve with the 3 spigots.
al mclean '93 XJS 4.0 - '84 4.2 Daimler - '84 DD6
Telford, United Kingdom
The archives and FAQ will answer many queries on the XJ series…
FAQs: http://www.jag-lovers.org/xjlovers/xjfaq/index.html
Archives: Jag-lovers Forums - Jag-lovers
To remove yourself from this list, go to Jag-lovers Forums - Jag-lovers.
