I have the engine and trans out of my '87 XJ6, and cut the P/S
hoses to get the engine out. I have to have a custom P/S
pressure line made (lump!). Which hose on the steering rack
is the pressure hose? I see that one hose is larger diameter,
but I’m not sure which one would be pressure, and which would
be the return. Thanks!–
1987 XJ6 getting lumped - 2004 LQ4 6.0/4L80E
Houston Tx, United States
In reply to a message from bsparks72 sent Sun 26 Dec 2010:
Ha, from memory???.
The larger one (10mm pipe) is the return.
The smaller one (8mm pipe) is the pressure.
Some one else will surely yell out if I am wrong or right.–
be the return.
The hose with both ends with a threaded fitting would be
the pressure hose.
You can take the old hose to any seal and fitting place and
have a new hose fitted to those fittings.
Walter--
In reply to a message from Doug Dwyer sent Mon 27 Dec 2010:
I have a steering rack with two hoses, each about a foot long, cut
with no ends on them. The old engine is long gone. Otherwise, as
noted, it’d be easy to tell!–
The smaller hose (inside diameter) is usually the pressure hose.
If the same as my '88 XJ-S then, looking at the pinion housing, the hose
closest to the rack is
the high pressure hose, the hose closest to the steering shaft coupling
is the low pressure hose.
TTFN
Bill
Surrey, UK
86 Daimler 4.2, 84 Sovereign 4.2 5spd man, 88 XJ-S 5.3 convertible 5spd manOn 28/12/2010 13:54, bsparks72 wrote:
