Hello all,
my wipers don’t park right. While they do work well in terms of performance,
and speeds, when I go to park them, they don’t return to their correct
position. I have to jiggle the windshield wiper stalk on the steering column
to get wipers in the correct spot. Where exactly is the wiper motor parking
switch??? What should I do?
Also I forgot where is the starter?? I would like to replace that as well.
Regards, Michael===================================================
Michael
the starter motor is located on the intake side of the engine, above the oil
pressure sensor/filter assembly.
cheers
darrin
84 SIII sov.===================================================
Michael: this is usual on a Series III car. The vatsy majority have wipers
that do n ot park in the normal mode, but will park in the intermittent
mode. This is NOT a function of the park switch, but is a fault in the
column switch. Most of us simply switch to intermittent to park the wipers.
Or you can replace the switch.
Gregory----- Original Message -----
To: xj@jag-lovers.org
Sent: Saturday, February 09, 2002 11:56 PM
Subject: [xj] wiper motor? and starter?
: Hello all,
: my wipers don’t park right. While they do work well in terms of
performance,
: and speeds, when I go to park them, they don’t return to their correct
: position. I have to jiggle the windshield wiper stalk on the steering
column
: to get wipers in the correct spot. Where exactly is the wiper motor
parking
: switch??? What should I do?
: Also I forgot where is the starter?? I would like to replace that as well.
: Regards, Michael
: The archives and FAQ will answer many queries on the XJ series…
: FAQs: http://www.jag-lovers.org/xjlovers/xjfaq/index.html
: Archives: http://www.jag-lovers.org/lists/search.html
: To remove yourself from this list, go to
