Hello to All.
I would appreciate any insight !
I am trying to locate the Wiper Relay on my 79 XJ12 Series II. On
the wiring Diagram the number is #251.
My wipers just stopped functioning. The motor works,
when I run it directly on both high and low postions.
This makes me believe the relay may be the problem.
I have power at the switch in the follow wires:
White w lite green, brown w lite green, lite green.
I also have power at the motor in the following wires:
Top Plug In / Ignotion ON Wiper Switch OFF - Pink, Lite Green.
Socket 1-D.
TopPlug In / Ignotion ON Wiper Switch on HIGH postiion - white,
lite green. Socket 3.
Lower Plug In / Ignotion ON Wiper Switch OFF - lite green Socket 4.
I have checked the fuse box, and fuses are okay.
I have also removed the wires from the wiper switch, and jumped
them together with the power sourse to the switch, but had no
results.
I can find info in the posts on series III, but not on series II.
Any help or insight on how to correct this madness would be greatly
appreciated.
Evertime an electrical problem comes up my British wife reminds me,
that all things worth having are complex …
Can’t live without wipers in Florida in the summer time (rainy
season).
Charles–
Charles
