Frank,
I’m just putting in a word for the transmission originally installed.
Considering that it cruises about 1800 to 2,000 at about seventy mph, and that 3,000 is a good healthy rpm for the v12, and that the redline is at least 6,000, and that 4,000 and above is really fun (and not legal anywhere, it seems like),…then we are only talking about economy!
I think someone is choosing the wrong tool for the job.
The biggest problem is that putt-ing around below 2,000 is where the problems in the HE head engine come from…causing the need for high speed runs to clean it out…and a jag V12 run between 3 and 4 thousand rpm, mostly, will need only to get onto the road more often…Drive it ‘Con Brio’ and don’t bother with Italian Tune-Ups, I suggest.
Money spent on fuel beats money spent on cleaning out carbon from choked up engines.
In my opinion, of course.
It’s a great car in snow, slush, crawling on rain-slick ice, and at 100 mph plus, on graded snow way below Zero in any language, and 125 - 145 mph on good pavement and good tires…(if there is anywhere you can find to enjoy that in this crowded & over-regulated world off the race track)
And I have never wished for a higher gear or for a lower one…but for me it’s for grand touring; long distances through open country at high speeds…and no slouch zinging down the Interstate…I wish for higher speed limits, not lower engine speeds.
GM 400 is cheaper to overhaul, “bullet proof” and as adapted for use by Rolls -Royce, Ferrari, Land Rover, etc., I think., as well as the V12 Jag, is a good tranny, and can be tuned up to be more responsive if desired, in the ECU as I recall…‘AJ’ comes to mind.
Marko should be sure, if he sticks with the GM 400 to be sure it meets the Jag 12 specs…and same for the torque converter; it’s
“special”.
Don’t mean you are wrong, Frank…but I’m just focusing on the intent of the Builder and the Owner…
When ‘they’ built the car ‘they’ were aiming at 27 mpg at 55mph…I suppose they got that; I just wouldn’t know, didn’t buy it for that !!
(grin…yellow teeth and sparse white hair but still grinning!)
Bill
Alaska
'86 V12 vdP Canadian Model
'71 xj LumpOn Dec 21, 2010, at 10:29 PM, Frank Andersen wrote:
elmarko wrote:
In reply to a message from Frank Andersen sent Mon 20 Dec 2010:
Thanks for the advice. It sounds like it is indeed time for a rebuild. I was thinking about picking up a second hand box, but I think best to rebuild the one I’ve got as a second hand one probably isn’t going to be any better.
It’s the devil you know, Marko…
I’m not at all sure that ‘shift - kits’ has any longevity relation - I rather doubt it. Altering shifting generally means tinkering with the valve body for some specific effect - so you better be clear as to what you want. The Jaguar did all this for us - arriving at some result considered suitable for the engine/body combination…and perceived Jaguar driver preferences. They likely also added longevity as a factor, though that is within the driver’s box treatment domain as well…
I doubt if they will guarantee that the kit fitted will make the box last longer - and if they do I’d like their rationale for so stating…
The real drawback on the GM 400, and indeed the 6’s BWs, is too few gears…
Frank
xj6 85 Sov Europe (UK/NZ)
I would like to look into firming up the shifts to help the transmission last longer. Do yo know a shift kit that would do the job ? I just fitted a Transgo full manual shift kit to my XJS with the 4speed auto box so I guess it would be a similar kit to that.
