In reply to a message from Bryan N sent Tue 6 Oct 2015:
did hit the vcm button and it says fail.
Checked fluid level, it is already higher than max.
I did the other things suggest in other posts. I start the
pump let it run till it stops, that is only a second or 3,
then I pump the brakes, first pump the pedal bottoms out on
something, it if far from the floor. It takes probably 35
pumps until it gets rock hard. Where next. Thanks–
Henge
Waynesboro/PA, United States
