In reply to a message from 30more sent Tue 8 Mar 2011:
Joe,
On the XJ40, you have to separate the functions of the ABS
and the brake boost from the ‘basic’ brake operation
involving pads and rotors.
If the pads or rotors are worn below minimum limits, by all
means replace them. The minimum thickness’s are :-
Front rotor = 27mm, front pads = 4mm
Rear rotor = 8.8mm, rear pads = 3mm
To test the efficiency of your Teves brake boost system
compare your car’s performance with what I consider to be
the norm :-
Teves Brake Boost / ABS pump performance
Typically, when my car has been sitting unused so that any
residual pressure in the accumulator has long since
dissipated, on turning on the ignition (without starting the
engine), the pump motor runs, the ABS light extinguishes
after 32 seconds, the ‘BRAKE’ light
extinguishes after 35 seconds and the pump stops after 42
seconds.
With the ignition still on, the pump will re-start on the
second application of the brake and run for 3 seconds to
recharge the accumulator.
Then, with the ignition switched off, it usually takes
exactly 30 applications of the brake before the pedal �goes
hard’ when servo assistance is lost.
According to the Jaguar Service Manual, the (nominal)
pressure in the accumulator on a Teves equipped car at which
these events occur is something like this:-
- Starting pressure = zero
- ‘ABS’ light extinguishes in 32 seconds at ~1400 psi
- ‘BRAKE’ light extinguishes in 35 seconds at ~1550 psi
- Pump stops after 42 seconds at 2700 psi (upper switching
point)
- After one or more brake application(s), pump re-starts at
~2000 psi (lower switching point) and runs for ~3 seconds to
‘top-up’ the accumulator.
- With the ignition ‘OFF’, as the accumulator pressure
dissipates (either through natural losses or brake
applications), the warning switches for the ABS and BRAKE
lights are actuated at ~1500 psi [which will then illuminate
the warning lamps when the ignition is turned back on].
You can also check the ABS system on a Teves equipped car
using the on-board ‘blink test’ - running out of characters,
so see what that involves in following post–
I did get a Fail…
when pushing the VCM
the second my red
brake light comes
on. I was thinking
it is time to change
my rotors and brakes
all around the car
but now I’m thinking
I got something else
Bryan N, '91 Sovereign 4.0 L, RHD
Cambridgeshire, United Kingdom
