A while ago I replaced the rear subframe bushings and the results
were dramatic. Now I’m setting my sights on the front subframe
mounts, front subframe bushings, and the two engine mounts. I seek
advise!
My thoughts are to lower the front subframe while supporting the
engine from above (engine hoist - where to hold engine from ?).
I’ll have to remove the power steering rack to do this, and I’ll
have to remove all the subframe mounts & engine mounts as I go.
But will I have to remove the front springs? By looking at things
a lot, it kinda looks like the whole front subframe can be removed
while keeping the springs in place. Can this be?
I’ll press in two new front subframe bushings (the round bushings
at the aft section of the front subframe), and I’ll replace the
two ‘‘V’’ shaped front subframe mounts, and also the two round engine
mounts.
Actually, it seems like this will be pretty easy (yea right). Any
input here? Am I taking the right approach? Do I have to remove
the front springs? Will I be selling a parts car soon?
Many Thanks!–
SteveC '89 XJ40 200,000 miles
California, United States
In reply to a message from Stevec sent Thu 1 Sep 2005:
Can’t answer your questions, but that’s my next step and I’m a
bit nervous since the whole suspension looks so heavy and
complicated. Please keep us posted with the progress…
I last did this on my X300 but the procedure was very similar to when I’d
done it before on my 1989 XJ40. You don’t have to remove the front springs
to remove the subframe assembly. You will have to remove them if you plan on
replacing lower wishbone bushes.
Most important consideration is safe method of supporting front of the car
(axle stands under front jacking points is best option) AND supporting the
weight of the engine (front engine mounts are bolted to, and supported by
the crossmember through large circular metalastik bushes). The weight of the
engine can safely be supported either from above with an engine crane or
with a jack under the sump using a large piece of timber to spread the load.
The car doesn’t have to be jacked up very high. The front raised about 6
inches gives enough clearance to slide the subframe assembly out.
The removal sequence is:-
slacken mounting bolts at rear of front subframe - 28 mm on X300 (30mm on
XJ40?) hexagon with nyloc
remove air intake & MAF sensor to access LH subframe bolts
slacken shock absorber and front Vee mounting bolts (2 per side on Vee
mountings) 17mm shocker top & 10mm Vee mount
support car body on axle stands under front jacking points
remove front wheels
remove front brake calipers from carriers & hang on wires from
(tie-down?) brackets
disconnect speed sensors from brake carriers & hang next to calipers
disconnect track rod ends
disconnect & remove speed sensor wiring harness (2 cable ties - top and
front of subframe)
disconnect steering rack pipe clips but leave pipes connected
disconnect steering rack pinch bolt
disconnect steering rack from subframe - 4 nuts & bolts and separate
from steering shaft
support steering rack on suitable block of wood and move it as far back
towards gearbox bellhousing as possible
support engine - jack under sump with LARGE block of timber to spread
the load or engine crane
support front of subframe (timber again to spread load). Trolley jack is
best
remove front bumper cover undertray (X300 only)
remove 2 rear suframe mounting bolts (slackened in step 1)
remove 4 top Vee mounting bolts
lower subframe on trolley jack and slide out from under car (have to
compress shock absorbers to clear front bumper cover or remove them
replace the Vee mounts (T40 torx bit on X300, M8 setscrews on XJ40)
whilst the subframe is out.
It’s not difficult but the subframe is heavy and assistance is useful,
particularly when putting it back.
Graham Gardner
Date: Thu, 1 Sep 2005 06:58:15 +0200
Subject: [xj40] Front subframe and engine mounts on '89 xj40
Hi Folks,
advise!
mounts.
In reply to a message from Graham Gardner sent Thu 1 Sep 2005:
Hi Gents
I have just finished replacing my 90+ xj40 ‘‘rusty’’
subframe/suspension with an 88+ xj40, (bought this as the donar car)
NOTE: Here is my approach.
Remove the mounting nuts at rear of front subframe - 29MM on a
XJ40…which is a non-standard wrenche in most tool kits. Leave the
bolts in place.
remove air filter & MAF sensor to access and slacken elbow and
move vetically to access LH ‘‘V mount’’ subframe bolts.
support car body on axle stands under front jacking points, nice
and high if removing subframe complete.
spread the load or engine crane, raise about an inch after removing
the top engine mount nuts, without having to removing fan shroud.
jack is best.
remove front wheels
calipers.
Remove bottom shock bolt
disconnect steering rack pinch bolt and almost pull off.
I disconnected the BIG steering rack pipe (NUT) and
disconnected the ‘‘loop’’ pipe that goes to the pump at the pump end.
This was because I found this pipe into the rack slightly corroded
and ‘‘glued’’ to its nut.
As I was dropping the the whole lot, rack included its easier and
this pipe comes out as part of the assy. So no need to disconnect
track rod ends.
Trolley jack is the only way. I found that due to the balance I
supported the subframe on the back 3rd.
13 . remove 4 top Vee mounting bolts
remove 2 rear suframe mounting bolts (slackened in step 1).
lower subframe on trolley jack and slide out from under car.
Now its easy to remove engine mounts as the bottom bolt especially
on one side is hidden by the rack. After going through this I would
drop the subframe if doing the engine mounts or ‘‘V’’ mounts as you
have to do most of the above anyway, Only you don’t have to move
the subframe out from under the car so it does not have to be so
high. Also make sure you have good combination spanners, sockets
will not take the pace on the rest of the ‘‘rusty’’ suspension nuts.
steve–
stevec 90 XJ40 4.0 Daimler 123,000mls
chelmsford, United Kingdom
In reply to a message from Steve455 sent Fri 2 Sep 2005:
Forgot to mention.
The engine mounts locate into the metal engine bracket
which are slotted, so although the engine mount threaded
part is at 45degrees it comes out without problems when the
subframe is lowered…bit tight getting it located when
putting back though.
While I used the earlier 88MY subframe/suspension assy
the disk/hub assy is different from the 90+MY. Although the
disk/calper/pads can be swapped for the later 90+ ones the
hole on the hub for the ABS sensor is not there. Be warned.
The ‘‘V’’ mounts on both my subframes were shot, the rubber
comes ‘‘unglued’’ from the metal and the only thing holding
the top and bottom metal halves together is a loose big
metal loop. You will see what I mean when you see one.
Effectively the subframe is moving about a bit. Now does
your car wander??? I think I’ll always order and change
these no matter what. steve–
