I’ve never seen this before on the dot-matrix screen, but I’ve got
a big ‘’!’’ with the words ‘‘FUELLING FAILURE!’’ under it. But the car
is running fine.
The battery died last week, and that’s when I got the message. I’ve
charged the battery, but the message won’t go away.
What is this thing trying to tell me?
Jess–
JessN16
Prattville, Ala., United States
You can use the VCM to retrieve the specific failure code. The
procedure details are available in the archives, but basically you
turn the engine off without turning the key all the way off and then
press the VCM button.
On my '88 I’ve experienced FF4, which turned out to be a failing O2
sensor, and FF6, which was caused by dirty/oily connections at the
TPS. These cars are sensitive to voltage level, so double-check the
health of your battery as well if it was recently discharged.
is running fine.
Jess
JessN16
