On my '91 with ‘block’ headlights I discovered that the left
main/high beam is not illuminating - all other lights front
and back working normally and therefore NO BFM warning on
the dash (sorry Dennis!!) because it does not monitor the
headlight main beams.
Started to check :-
- Bulb? - looked OK and continuity check main filament good
- Fuse? - B8 in left fuse box good
- 12 V to one side of fuse? - Yes
- 12 V on Brown/orange wire at BFM board? - No!
- 12 V out of back of fuse B8? - Yes.
- 12 V on pin 7 of Black connector LS29 at BFM? - No.
[However a couple of times I saw something around 5 volts at
that pin so I checked pin 8 which gets battery voltage from
a different fuse on a Brown/pink wire for the dipped/low
beam and fog lamp and that was at 12.7 Volts] - Detached left fuse box and unplugged the Black connector
LS72 which carries the Brown/orange wire on pin 3 - as far
as I can see uninterrupted all the way forward along the top
of the left inner wing to the BFM Black connector pin 7. - Checked continuity pin 3 of LS72 to pin 7 of LS29 - NONE!
I can only therefore assume that somewhere in that thick
loom the Brown/orange wire is corroded/broken.
To prove that the rest of the system especially the BFM
(Dennis) is good, I reconnected everything and ran a wire
from the battery positive terminal which I touched on to the
BFM circuit board at the point where the Brown/orange wire
terminates and, with the headlights switched on and main
beam selected, the little relay energised and the LH main
beam filament illuminated like a good’un.
If my analysis is correct and there is a break somewhere
along the length of that Brown/orange wire (which I assume
will be hard to locate) I do not fancy going to the trouble
of re-wiring from the back of the fuse box all the way to
the BFM connector. My initial thoughts are that I will run a
wire from the battery positive terminal via an in-line fuse
and splice it in to the Brown/orange at the BFM to get
battery power to the board to power that left main beam.
I will of course have to leave fuse B8 in place otherwise I
get the dreaded fuse fail warning on the dash!
Anyone have any alternative thoughts on the matter?–
Bryan N, '91 Sovereign 4.0 L, RHD
Cambridgeshire, United Kingdom
