In a message dated 11/11/2006 3:00:32 PM Eastern Standard Time, “Cormac” ac.okeeffe@totalise.co.uk writes:
I still have not twigged on
how to remove the sunroof. � Haynes Manual has no useful guide. � �
Hi Cormac,
The headliner material on the sunroof panel is glued to a piece of sheetmetal that can be removed after removing the exterior (painted) sunroof panel to the outside (the inner panel stays inside). The following is the procedure I followed on my 89:
Open Roof Panel to Near-full open position
Remove 4 PZ2 screws @ front of roof panel, horizontal axis
Close roof panel to 2"-open position
Lift upward on front end of panel and pull forward & upward
Ensure rear of panel disengages @ seal plates, on each side 3/4 of way to rear of panel
Lift out panel, preventing metal to metal/paint contact
If seal is intact, this will provide a buffer between panel and metal aperture of roof opening
Headliner metal panel that shows on inside of sunroof is held by 10 nylon 90-degree nuts.
Have not worked out where I am going to get material from yet.
Just make sure the fabric and the foam rubber that is bonded to the fabric do NOT exceed 1/8" thickness, or you will have problems with the sunroof fabric dragging in the aperture when the roof opens. Some shops sell a fabric with foam nearing 1/4" thick and you do NOT want that.
Channel Islands is not dripping with suppliers as you might
imagine.
In the US, small-town fabric shops often carry headliner material (foam bonded to fabric).
The courtesy light unit looks too fiddly to bother
replacing lining on so I think I will leave this.
It does take some dis-assembly, removing the wood trim, etc., but can be done in an hour or so.
I might actually pay an upholsterer to fit the lining to the board
because last thing I want are creases or bumps.
The secret is in the application of the spray adhesive, and whether you can get the right adhesive at a reasonable price. When I did mine, I was also having some upholstery replacement done, and the shop doing that glued the new material to the board (after I removed everything and gave them a clean board to work with) for about what the adhesive would have cost me in individual spray cans.
85 & 89 XJ-S Coupes; 89 XJ40 VDP
