In reply to a message from Tophatchef sent Mon 1 Jun 2009:
This is what you need to drain and re-fill the differential
http://www.jag-lovers.org/snaps/snap_view.php3?id=1145470011
First (repeat FIRST) remove the fill / level plug in the
back cover of the diff just to make sure that you can
remove it to re-fill the diff after you have drained it.
I find it essential to tackle that from below, so make sure
that the car is properly supported on ramps and / or axle
stands.
Drain the old oil by removing the drain plug in the bottom
of the diff (accessible through a hole in the rear ‘A’
frame). Pay particular attention to any metallic deposits on
the magnetic drain plug. If you see any substantial evidence
of that, the chances are that something internal to the diff
is badly worn and you may need a replacement differential.
You need 2.1 litres of differential oil. After replacing the
drain plug, you replenish the diff oil until it runs out of
the fill/level plug hole. It is a bit messy.
There are three main ‘noise generators’ in the diff - the
output shaft bearings (can be replaced with the diff still
in the car), the pinion bearings and the main carrier
bearings (the last two require the diff to be removed for
strip down to effect replacement - a BIG job, see archives)
I’m not familiar with the differential lubricants available
in the US - others will advise you on that score - but
replacing the diff oil will never cure the fault causing
the noise.–
My car is STILL making a loud noise from the rear, and the
only thing left is the differential. How do I locate where
to check the oil level? check the level of the oil? Drain
the oil? What oil to I buy to replace the oil? Am I better
off going to Jiffy Lube or some place like that?
Bryan N, '91 Sovereign 4.0 L, RHD
Cambridgeshire, United Kingdom
