hi there, I have a 94 3.2 xj40 and cant seem to get a spark at the
coil. I have a live feed going to it and have changed the coil and
amplifer but still nothing. any ideas or tips would be greatly
appriecated.thanks nick–
xj40nick
In reply to a message from xj40nick sent Mon 23 Jun 2008:
Probably the single most common cause of ignition failure is
the CPS failing.
Without the CPS, the ignition amplifier never gets a signal
to trigger the coil.
Often with a failed CPS the tachometer will not move when
you try and start the engine. I’ve seen the tach move
during a no-start caused by a bad CPS, so it’s not a rock
solid clue for all no-starts but if the tach does not move,
it’s nearly a sure bet its the CPS.–
In reply to a message from Win sent Mon 23 Jun 2008:
hi thanks for the info its much appriciated. by CPS do u mean the
the unit under the dash on the passenger side? thanks again. nick–
xj40nick
Nick,
Nope, the CPS is the Crankshaft Position Sensor, front of
the engine, above the main pulley. My apologies, I should
have defined the acronym.
Very easy to replace, has a single bolt (usually a 5mm allen
head, sometimes a 10mm hex head) down at it’s bracket, a
single three wire connector up at the front of the valve
cover and usually a nylon wire tie to secure the wires and
keep them out of the belts.–
hi there I changed the c.p.s and still no spark at the coil! does
anyone know what the next thing to check/change would be? any help
would be brillient as im close to pullingmy hair out!–
xj40nick
hi there this is the latest update on my on going saga! I have no
spark at the coil but have a live feed. I’ve changed the coil,
amplifier, e.c.u and c.p.s. I have movement on the tacho when I
crank it over. I’ve pressed the vcm button to see if it came up with
any fault codes but instead of a number it came up with what looked
like P.A.O. any help would be greatly appriciated as I dont have a
clue what else to try. thanks, nick–
xj40nick
In reply to a message from xj40nick sent Wed 16 Jul 2008:
Hi Nick,
P.A.O – is actually ‘pad’ as in brake-pad - not related to
the engine at all… but might indicate a worn-out brake pad
or a broken circuit - nothing to do with the real problem
you have…
You say you have a live supply to the coil, can you measure
the resistance of the primary? It should be only 2 or 3
ohms. I wonder if it’s gone open-circuit.–
The VCM fault code you see is ‘PAD’ which is a brake pad
wear sensor warning - nothing to do with your ignition problem.
You say you have power to the coil (battery voltage on the +
terminal on the White/pink wire?). Do you also have battery
voltage to pin 2 of the black 7-way connector on the
ignition amplifier on a White/pink wire when the ignition is on?
Do you hear the half-second priming burst from the fuel pump
each time you turn on the ignition? If not, have you checked
the EMS main relay - the one in the black base in that group
of relays on the firewall in the engine bay? If there is a
problem with that relay you will not get power to the EMS
ECU - and hence no sparks.–
In reply to a message from MikeSW17 sent Wed 16 Jul 2008:
hi there mike im not good with electrics so your have to bear with
me! I’ve just gone and checked the resistance on the coil and it
showed up as 1 ohm–
In reply to a message from Bryan N sent Wed 16 Jul 2008:
hi bryan thanks for the reply. yeh I’ve checked and have a live to
the black connector. what sound should I be listening for with the
priming burst and where from?. thanks again, nick–
Remove the filler cap from the fuel tank and put your ear to
the filler neck. Then get someone to turn the ignition on
and off a few times - you should hear a short ‘brrrr’ from
the in-tank fuel pump each time the ignition is turned on.–
In reply to a message from Bryan N sent Thu 17 Jul 2008:
sorry I was being stupid I realised what u were talking about after
i sent the post. yes I can hear the fuel pump when I turn on the
ignition. does this mean it wont be the e.m.s–
In reply to a message from xj40nick sent Thu 17 Jul 2008:
Yes, that should clear the EMS relay.–
I sent the post. yes I can hear the fuel pump when I turn on the
Hi
1 ohm is about right for the primary coil.
What do you have on the secondary (between the HT output
terminal and the -ve terminal)? You should see something in
the range 5k ohm to 8k ohm.
What year is your car? In pre-93 cars the tachometer signal
comes from the -ve terminal of the coil. On later models, I
think, the tacho is fed from the ECU.
If yours is pre’93 then the movement you see on the tacho
confirms a pulsed signal at the coil primary.–
showed up as 1 ohm
In reply to a message from MikeSW17 sent Thu 17 Jul 2008:
i’ll check the secondary when I get home from work today, my car is
a 1994 3.2 so the tacho if fed by the ecu. do you think running a
diagnostic on it might shed some light on whats at fault?–
Without the right test equipment, it’s difficult to test if
you’re getting a pulsed (on/off) signal at the coil primary
connection. Might need an 'scope.
Alternatively I’ve read about testing the coil by
disconnecting the +ve and -ve wires, connecting the coil -ve
direct to a ground (-ve) on the vehicle and taking a wire
direct from the +ve of the battery and ‘flicking’ it against
the +ve terminal on the coil.
This should generate a spark if the coil is Ok. I’ve not
tried this and can’t confirm it, but it makes sense. But
take care - you can still get a nasty back-emf jolt from the
low volt side of the coil!–
hi I was checking the coil again and I noticed im getting a slight
earth from the live terminal when I tried a continuity test is this
normal? thanks. nick–
