Hi
I have looked through the ach’s but I can not really find what I’m
looking for. I have just picked up my first jag XJ40 on a 91 J
Plate.
When I collected it the viscous fan clutch had sheared sending the
fan blades into the rad. I replaced both and that system works
fine now. I only mention this for completeness and possible
connection.
My real problem now is that the brake warning light is always on.
Pressing the VCM brings up PAD and FAIL. I have not had the
opportunity to check the Pads yet, but it’s the Fail that really
bothers me. Can the FAIL light be because of the Pads or is it
something else?
If it is something else how do I diagnose what has failed?
Also, while I’m thinking about it. The fuel gauge does not move.
Is this more likely to be the sender unit or the gauge it self. Is
it right that if you ground the sender unit the gauge will go to
full? If so will that indicate the sender unit failure.
I appreciate all the help you guys can give me.
Regards
Idris–
Idi
