I have tried tightening the pinion nut on a few differentials,
some I could move it, on others, I could put a 5 foot pipe on the end
of a ratchet, stand on it, jump on it, and not budge the nut.
I did get good results if I could just turn the nut slightly, I
marked the nut, then moved it one degree? and reduced the noise
quite a bit.
I did not notice any more force needed to turn the diff in the backlash
mode.
I thought, a little is good, so more is better, and went another degree,
and things were very quiet for a while, then a very nasty grinding noises
stared coming from the differential.
I thought, ok, I trashed the bearings.
I bought a rebuilt diff and fit it, took the original diff apart and found
the bearings looked like they had 80,000 miles on them (they did),
but nothing really wrong. The races looked like the typical wheel bearing
with mileage on them, not bad, just some signs of wear.
Before taking the diff apart, I found the pinion flange easy to turn,
with grinding noises, and on taking the nut off, found it somewhat loose,
and after inspecting things and tightening up the nut, found the diff
smooth and quiet.
When the rebuilt diff got noisy (10 months later), I tried to go one
degree on the nut, but could not budge it.
I think its a valid method to get rid of the noise by tweaking
the pinion nut, to remove the play from bearing and gear wear
(slight but noisy), as long as you don’t go too far, and the nut
stays tight.
I never tried removing the nut, adding fresh locktite, and re doing it, as
the marks might be lost, and you would need to really play with it in order
to get the preload correct, and I don’t know if you could with the diff
in the car.
Dealers do it with seal replacement, and maybe you could just
get them to go a bit more tight on the nut than it was, say 1 degree…
New sub frame bushings and thicker lube might be a better idea though.
Keep in mind, I made lots of experiments out of curiosity,
both with differentials and drive shafts, looking for a really quiet
and smooth car.
Brett
1990 XJ6 (quiet differential)
Jerry,
On an XJ40, there is not a torque figure specified for the pinion
nut itself in the Tech Specs. The pinion bearing pre-load is set
using the crush tube method by measuring the BACKLASH torque ( i.e.
the torque required to take up the play between the crown wheel and
pinion) and that is measured only in lb/INCHES (Spec = 35 - 55
lb/inch).
It’s a ‘one-shot’ type excercise because if you tighten the pinion
nut a fraction too far and exceed the backlash torque specification
the crush tube is knackered and you have to start all over with a
new crush tube.
On my car, the pinion nut itself was so tight, I could not undo
it with a long breaker-bar when I tried to replace the pinion shaft
seal. I had to take the car to a shop and have them remove it with
an air impact wrench. No doubt that was due in some part to the
application of ‘thread lock’ during initial build, but if that is
the case with other XJ40 pinion nuts, you really have no chance
of ‘tightening it up a bit more’ as you suggest without a serious
risk of overdoing it, exceeding the backlash torque, ruining the
crush tube and if left in that state, the pinion bearing itself.
As Brett has mentioned, he found out that messing with the pinion
nut is at best a temporary relief and IMHO it potentially will do
more harm than good.
Read the bit you said about whine on overrun- check the pinion
nut torque, and find the spec for what pinion bearing preload is
supposed to be-if it has loosened up even slightly, maybe you can
get some silence by tightening the nut up a bit more, not to exceed
spec from Tech Data.
Bryan N ('91 Sovereign)
Cambridge, United Kingdom
Visit the Jag Lovers homepage at http://www.jag-lovers.org
for exciting services and resources including Photo Albums,
Event Diary / Calendar, On Line Books and more !
