Test XJ40 electric door locks
Here’s what I learned troubleshooting an inoperative RF door
lock on my 89 XJ40 LHD. This post is for the archives, in
hope it will assist someone else experiencing an electric
door lock problem in future.
Operating properly…
Locking/unlocking either front door lock with the key locks
and unlocks the other 3 doors
Pushing the dash panic lock switch locks all the doors and
closes the sunroof.
Holding the key in locked position in either front door
(locks the other 3 doors, and) closes the windows and sunroof.
In my case, locking/unlocking the driver door lock did not
lock/unlock the RF passenger door, and vice versa.
Testing the right front door lock:
For purposes of this discussion…
With the LF door lock actuator unplugged, orient it’s
harness plug so you are looking into it’s open end at
the pins, a pair of pins on top, and the remaining
trio of pins on the bottom.
Start with the left top pin, call that pin 1 and
proceed clockwise, numbering the pins 2 through 5,
respectively.
Pin 1 has a yellow wire w/orange stripe
(senses lock position?)
Pin 2 has a purple wire w/red stripe
Pin 3 has a purple wire w/pink? stripe
Pin 4 has a purple wire w/white? stripe
(activate the lock motor in either direction)
Pin 5 has a black wire w/white? stripe
(ground?)
Consider the unplugged connector attached to the actuator…
attach test leads from the positive and negative
battery terminals to pins 3 and 4… the lock actuator
should move; -
reverse those connections on pins 3 and 4 and the
actuator should move in the opposite direction.
If powering these 2 pins does not elicit actuator
movement, this likely means the actuator is dead
and needs replacing. This was the case on my car. -
Consider the receptacle this plugs into on the harness,
and number each socket with the same number as the pin
that fits into it.Using a multimeter on an appropriate scale to measure
12 volts, I found that:-
socket 2 has 6 volts with the car doors locked and
socket 1 grounded. -
With the car doors unlocked, those 2 sockets reverse
and now socket 1 has 6 volts with socket 2 grounded. -
There will not be any voltage across any other pairs
of sockets.
You could connect the multimeter across sockets 3 and 4
and you should measure either +12v or -12 volts
momentarily as a lock key is turned, depending on whether
the key is locking or unlocking the doors.
Test 1, above, indicated my problem was a bad
acuator motor, so I did not try this test.
If you don’t see a 12v needle jump on this
test, then I’d suspect a harness problem or a central
lock controller problem (it’s a black box under the
passenger dash, next to the console). -
Hint: don’t replace door upholstery for a day or two, until
you are certain things work properly–
84 XJS, 89 XJ40
Santa Barbara, CA, United States
