Last evening I put 325ml of ‘Wynns Dry Fuel’ in my tank.
The tank was about three quarters full so it must be a pretty dilute
mix.
(It was a precautionary thing, lately with high humidity and temperature
changes the conditions are good for condensation in the tank)
This morning (normally excellent starter) it started and ran for about 3
seconds then stopped.
After that it just ‘huffed’ a bit on the starter and once with the pedal
hard down to weaken the mixture it fired a couple of times but wouldn’t
catch.
On the Wynns bottle it says ‘Contains kerosene’ (it doesn’t say if it is
just and only kerosene); kerosene to me means paraffin.
If it is just kerosene, would it go to the bottom of the tank so that I
am now trying to start on paraffin instead of petrol?
The plugs show that fuel is getting to the cylinders, and when dried the
plugs spark OK and the rev counter moves showing maybe 100-150 RPM. when
cranking.
The battery is 2 years old and never been ‘stressed’ (the car normally
starts immediately) and if the car is not to be used for a day or so I
put a trickle charger on it.
Is the Wynns likely to be the cause of my non starting?
I’m leaving the plugs out overnight to ensure that the cylinders are dry
and the battery is on charge.
Any ideas?
Richard–
A.R.Mills
1992 XJ40 Daimler 4.0Ltr
Somerset; UK.
