Hi all
I have trawled the archives without any reall suscces. The topic has come up
before but I cannot find any defintive answer.
The security code is, based on the series of soldered links visible through
a small hole on the back of the radio (AJ9100 and AJ9200).
Question, how do you convert the 6 digit pad code into the 4 digit security
code ?
The code is not simply a row of 6 links with two missing therefore giving a
4 digit code.
The soldered links will in effect give a 6 digit series of 1s and 0s (1
being a link, 0 being open)
For example, I have one here that would have a pad code of 100111 and has a
security code of 6354.
I did wonder if it was a straight binary - decimal conversion but that is
not the case.
Has any clever bod out there actually cracked the system ?
Phil
Find us at
www.xjjaguar.co.uk/
Call (+44) 01323 740471 ( 0900-1730 Mon-Fri, 0900-1330 Sat GMT ONLY)_________________________________________________________________
Could you be the guest MSN Movies presenter? Click Here to Audition
http://www.lightscameraaudition.co.uk
