Some advise please , My BW Transmission is back in the car after an overhaul drives like a dream , however the Kick down switch and wiring is non existent ,the repairer advised of this when work began and suggested a switch mounted on the throttle with power from the horn and connected to the solonoid ? My repair manual says the switch should be around the accelerator inside the car , again no evidence of this either .
My question ,is the proposed throttle mount solution viable ?
Thanks again
Kirbert
2
OEM setups typically have the kickdown switch somewhere on the throttle and requiring an extra push at full throttle to engage â why itâs called âkick downâ. Hence the driver has the option of applying full throttle without kickdown, if thatâs what he chooses to do.
On the V12 XJ-S, though, the kickdown switch rarely works. For one thing, the pedal itself is too weak, so when you push it to try to get kickdown it just flexes rather than engaging the switch. After enough time it even takes a set, so it couldnât engage kickdown on a good day. That all can be corrected, of course, but itâs of interest to note that some owners prefer to do away with the manufacturerâs intention here and instead install a microswitch on the throttle that engages kickdown without requiring the extra push, just roll the throttle on and it kicks down. The guys who do this often claim they vastly prefer how the car drives when itâs so quick and easy to get it to kick down. I suppose some who bought the car for its luxurious and serene ride might not care for all the downshifting.
You definitely want kickdown to be available. Whether or not you want it to require a decision or to just come on whenever youâve opened the throttle is something only you can answer. Either one shouldnât be too difficult to rig up. I do wonder why yours seems to be missing.
Hi Craig,
This is the setup on my S1, a Daimler Sovereign fitted with the BW Type 12. I think the setup with Type 8 is different, but this is probably what you need.
Automatic transmissions downshift âon demandâ - depending on road speed, engine rpms and pedal position. Ie, while the box is programmed to upshift quickly with light throttle; if pedal is applied the box will downshift when it deems it âappropriateâ - driver demanding more power as expressed by pedal position.
The kick-down is not really required; when you floor the pedal, the box will downshift within the relevant road speeds. The kick-down switch is sort of more positive - but if road speed is too high the kick-down switch will not cause downshift. Downshift limits are meant to prevent overreving the engineâŚ
The BW8 has no solenoid, but a linkage that runs from this throttle linkage to the left of the transmission.
Mounting the switch to the linkage as in the photo makes sense.
I rarely rely on kick down; for spirited driving I shift between âDâ and â2â keeping a watchful eye on the tachometer - gives a more positive and reliable gear shift.
This is the switch on my 1971 - fitted to the end of the accelerator cable.
Thatâs exactly what I have on my '72 and this is correct for a BW12. This is the box the OP should have in a '73 Daimler. The last bit of accelerator travel pulls the inner and outer of the cable down into the sleeve in Frankieâs photo, a cam action trips a microswitch and a message is sent to the kick down solenoid. QED. Paul.
It appears to depend on which carburettor enrichment device is fitted. The early (ASC) cars have the switch in your photo Kevin, but the later (AED) cars have the switches as fitted to mine and Pauls. I have the AED set up and presumably Paul is the same, but you have the ASC Kevin?
