Have seen similar problems many times and unfortunately now it’s my turn asking for help. The situation is as follows:
Completely rebuild 1954 engine with SE spec, engine did meanwhile 50 mls (running in between 1500 and 2500 rpm).
Engine starts immediately with original Otter switch, starts at 800 rpm and climbs up to 1100/1200 rpm within 2 minutes (car standing, not running). Engine runs very smooth with AED on, without becoming “lumpy” towards the end of the “choke” period. Otter switch then cuts AED off and engine runs at 600 rpm without any problem. Temp gauge still “cold”.
Start driving the car and engine runs beautiful, picks up fantastic at any rev in all gears and lots of power. Temp gauge climbs up to 75 C after 20 minutes driving. So far, so good.
Once the engine is warm (so after 20 to 30 minutes), it’s very difficult (or better almost impossible) to accelerate from 1500 rpm upwards (in all gears). Lots of hesitation, not wanting to rev above 1500 rpm. The only way to get higher revs is to very slowly and gradually push the accelerator pedal carefully down, in which case the engine will slowly increase revs to about 2000 rpm, no more. When pushing the pedal down quickly the engine will protest and much more hesitation. Don’t know whether I should call this “misfiring” but fortunately there are no “explosions”.
After the engine has cooled down (several hours), it runs fine again until it becomes warm and the above story repeats itself.
I replaced the (hot) coil and quickly switched it for another (cold) coil: no changes, same engine behaviour.
Compression is fine (all around 140 psi). The dash pots are filled with SAE 30 oil. Spark plugs have a nice colour and no “soot”. I’ve already set the mixture a quart of a turn of the screw downwards (so richer) but nothing has changed.
I know it’s very difficult to diagnose from paper, but where should I now look first: ignition or fuel? Is the engine hesitation caused by “misfiring” of the ignition system or still a mixture problem? Or something else?
Your experience is welcome.
