I’m hoping that someone might have a suggestion for my poor idle problem, as I’ve done about everything I can think of.
The engine is the original from my 53xk120 fhc project, mounted on the restored frame, so not a drive-able vehicle. It came to me over-bored to 3.8 L. Sonic check was ok, and I added .020 to clean up. New pistons are 9:1, cylinder head modified with big valves, xj6 size, mild porting (compared to my spare head .050 out board, zero mid, .080 deep), Bill Terry’s WAD street cam, manifold inlet opened to accept 2" HD8s. Carbs are rebuilt (added upgraded spindle seals yesterday) and jets are centered, UM and UO needles tried, float levels correct. Mallory dual point (recently removed one set of points with no improvement), new condensor. Pertronix coil (no change with Lucas coil). Standard plugs and gaps, new wires. Stock exhaust manifold, dual SS exhaust. Rebuilt square body fuel pump with modern internals.
So, the engine starts pretty easily, but doesn’t like to idle without the throttle cracked open. Bypass screws pretty much wide open, and timing advanced to 16 BTDC to maintain a lumpy idle between 650 and 750 on fresh, premium no alcohol fuel. Manifold vacuum 12-14, very erratic! Idle shoots up to 1600 with the starter carb in maximum lean. I’ve had the intake off twice, and the surfaces are dead flat - I don’t think there is a leak. And plugs are always sooty! If I lean the carbs until the engine stumbles, they are still black. I’ve never had trouble tuning SUs for idle, and I can find nothing wrong with these, but changes in settings don’t seem to affect idle that much. On the other hand, it revs great, runs cool, carries great oil pressure on the original pump (modified to xj6 spin-on with external oil cooler). I’ve quadruple verified TDC on the 420G vibration damper, and confirmed that cam timing is dead on. Spark is strong at all plugs. Head retorqued, compression even across at 165psi.
Bill Terry has been very kind with suggestions - he tells me that in his shop, engines with his cams and with similar mods all idle well. They have more trouble getting them to be rich enough under load. I was thinking that the engine might be overported, but I don’t think my measurements suggest that. My next step is to try the original SE cams on the engine, as the engine behaves like I’d expect with a high lift, long duration cam - this cam is not supposed to be that aggressive. Seems like it wants more air. Just wondering if anyone else has an idea here. I’ve run 10 gallons of fuel through it so far, and I’m not finding it. What am I missing?
Ron
