Tom,
Mark is still bouncing, so I’ve forwarded his comments below.
I’ve personally installed one of Ron Moore’s kits into a 78 XJ12 (Man,
was that an eye opener ! Wheelspin in 3rd gear at 80 km/hr !)
I documented a blow by blow of doing the conversion into the XJ
archives. Do a search on XJ12 manual conversion.
Don’t know if Ron Moore is still in business but if you like I can find
out. Dellow are certainly in business, from my personal experience I’m
not sure I’d buy his kit a second time, pretty near everything you want
is available from Dellows (largeish firm as opposed to Ron who’s a
backyarder) and you’ve got the nous and experience to not need the hand
holding which is basically Ron’s value add on the Dellow kit.
JL
XK admin
(Sydney Oz)-------- Original Message --------
Tom,
Ron Moore sells a kit made by Geoff Dellows. If you check the archives you
can find his e-mail address. There are two, both are bigpond. The older one
is something has sb in it somewhere. The newer one includes his name, IIRC.
The hardest part of the job is finding a LHD pedal box. I got lucky.
The next hardest part is finding the right transmission, although your
situation may be different because you aren’t working with a 2.88 rearend.
Check the Jaguar literature for the ratios of their 5-speed, then compare
that with the four Supra series trannies available, W55-W58. Get the one
with the closest match, although you may want to go a bit higher on the
overdrive. You can do the calculations to figure out what the speed will be
at what rpm.
Mark
-----Original Message-----
From: owner-xk@jag-lovers.org [mailto:owner-xk@jag-lovers.org] On Behalf Of
Tom Carson
Sent: Tuesday, October 19, 2004 7:59 PM
To: xk@jag-lovers.org
Subject: [xk] XJ6 manual conversion
XK Listers,
Forgive me, for this blatant cross-list inquiry, but I know you guys…
I may an opportunity to buy a pretty nice early Series 1 XJ6 with factory
steel sunroof here in Juneau. If I do manage to score this car, I want to
put a manual shift 5-speed in it.
Mark Stephenson and others: isn’t there a Toyota Supra kit out there for
guys like me?
Any contacts or details would be appreciated.
Tom Carson
1954 XK 120SE OTS S674946
1962 3.8 Mark 2 MOD, chrome wires
Juneau, Alaska
