On May 14, Ron Radar asked about converting an XK 150 from
generator to alternator. I explained the factors that
influenced my choice, and in response to follow-up inquiries
about how the conversion was accomplished, I offer this.
We’re using a 100 amp Ford alternator in place of the 30 amp
Lucas generator. While it has higher output, it is smaller.
The original generator bracket is on the engine, but only
the front hole is used to mount the alternator.� The rear
hole will be used to secure a grommet for the combination of
wiring that will carry the higher out put.
In addition to the No. 10 generator wire in the wiring
harness, we’re using a No. 8, (MIL-W-22759/41-8�ETFE
Insulated, �nickel coated copper conductors,�133 strands of
29AWG), which, added to the No. 10, will provide the cross
sectional� equivalent�of a No.6 wire�(a wire cross section
area of 13.3 mm2).� Assuming 65 amps output at 14.2 volts at
the alternator,�and a run of 10.75 feet, it will have an
output of over 13.5 volts at the battery/ starter.
A related issue involves the alternator pulley. While Rob
was able to align it with the other pulleys, the Ford pulley
has a different groove width for the belt. We decided to
change the pulley on the alternator, and at the same time,
address another issue:� the engine pulley on a Ford is
smaller than the engine pulley on the Jag, so to keep the
alternator speed about the same, the diameter of the
alternator pulley should be increased.� Rob was able to find
a 2 7/8’’ Jag pulley to replace the 2 3/8’’ pulley that came
with the alternator.
Rob cleaned up and bead blasted� a 2 7/8 inch Jag pulley.
The required modification was to reduce the boss on the back
of the Jag pulley (to align with the engine pulley) and
enlarge the hole to fit the shaft of the Ford alternator.
Rob installed a new wiring harness, with sightly revised
routing, that goes through the trapezoidal support (I
believe the Jaguar description is ‘‘front inner wing
support’’). The yellow No. 10 generator output wire in the
wiring harness will be combined with the mil spec No. 8 to
take the alternator output back to the battery. While the
Ford alternator is a single wire setup, the casting has a
rubber plug where the other two wires were located on some
models. Removing the plug disclosed that one of the
connections could still serve to power an ‘‘idiot light’’.
Thus, the green/yellow wire in the harness that originally
energized the generator will be connected to the ‘‘idiot’’
light socket in the alternator and power the ignition light
on the instrument panel.
Monte
1960 DHC
S838594
http://www.jag-lovers.org/v.htm?1242435535--
p8099
