Here is the latest on the alternator conversion:
My local AutoZone was kind enough to let me peruse their alternator
inventory in search of one with a similar configuration to the Lucas
generator. After going through about 20, I found a 52 (or 55, depending on
where you look) amp Motorola alternator with the exact same pulley
placement. In case anyone is interested it is AutoZone part number 7429. It
will bolt on the front of the generator bracket just like the generator,
with a 3/8x8" bolt through the alternator, the bracket and steel tube (for
rigidity) and out the back. The alternator was a mere $39.99 + $15.00 core.
The only drawback is that it doesn’t have a built in regulator, so I had to
track one of those down. Again AutoZone was very helpful, helping me search
the pages, looking for the number amidst all the generator numbers listed. I
told them to take care of other customers and I’d continue the search and
much to my surprise, and theirs, I discovered a listing of applications by
alternator number at the back of their book. That’s how I discovered, much
to my chagrin, that it was early 70s American Motors. They had a regulator,
but I wasn’t sure how it was going to work, so I held off on that.
Then I went to the library, in disguise because I didn’t want anyone to
recognize me as I checked out books for early 70s Gremlins, Hornets, and
Matadors. (How embarrassing!) After learning how the regulator fit into the
scheme of things, I returned to AutoZone for the VR727 regulator, US$16.99.
Both have lifetime warranties.
After examining Gremlin and XK120 (I hate to use those two words together in
the same sentence.) wiring diagrams in detail, and while it’s still fresh in
my mind (before I head off to bed), I’m hoping some of the electrical
geniuses on the list can verify my theories regarding alternators vs.
generators.
With a generator and a regulator, the regulator controls the output of the
generator directly by adjusting the voltage and amperage before it flows to
the battery. As I see it, the raw generator output doesn’t change (unless
the field strength is adjusted to control output). The regulator for an
alternator, on the other hand, controls the alternator so it only puts out
the amperage needed to power the electrical system and charge the battery.
Am I correct so far?
If so, I’ll continue on my mad dash to electrical nirvana…
I want to keep as many of the original components with the car in case a
miracle happens and the original engine turns up. I have the RF95 Control
Box, which includes a terminal block and some fuses. I’ve figured out what
goes where and why, and rather than reinvent the wheel, I might as well use
the terminal block feature of the control box. It seems to me that I’d have
to disable the regulator part of the box, though, since I’ll be powering
directly to the battery from the alternator.
Am I still on the right track?
It seems that to adapt the RF95, all I would need to do is disconnect the
ground wire from terminal E; remove the field wire from terminal F, since
I’m going to use that wire for the new regulator; and move the generator
(now alternator) output wire from terminal D to terminal A. At that point I
would have a really impressive looking terminal block, right?
Finally, I want to keep extraneous wires to a minimum. I have the 10 ga.
yellow wire that ran from the generator output to the D terminal on the
RF95, that will now run from the alternator to terminal A. I don’t want to
fry that wire, and I know the 75 amp Lucas alternators use two 10 ga. wires
from the alternator, so I was considering a second 10 ga. wire that would
run from the alternator output to the big battery wire post on the solenoid.
Anyone see any problems with that?
Then I just have to connect the American Motors regulator wires to the
proper terminals on the back of the alternator and I should be in business,
correct?
Assuming that I have figured out everything so far, the only thing I’m not
sure about is how the alternator ties into the ammeter. Even if someone has
converted to an alternator with a built-in regulator, I think your
connection method will still apply, because there aren’t that many options.
As far as the ignition light goes, I have a little better idea, I think.
There’s a wire that runs from what is called the “regulator terminal” on the
alternator to the regulator, and on the Gremlin, it also seems to run to the
ignition light, then to ground. However, I wasn’t sure about the schematic
because the ignition light was not specifically identified. It was the only
component, lumped into the dash circuitry, that had a line running from the
regulator. Does that make sense?
I know I’ve asked a lot of questions, but I hope that the listing of the
alternator and regulator part numbers will be some miniscule repayment for
the information I have and will continue to receive from the great minds of
the list.
“Mark 1” Mark Stephenson
1952 XK120 Roadster #673129 (w/XK140 engine and C head)
1958 3.4 Litre Saloon / 1984 XJ6 4.2L / 1985 XJ6 VDP
Jaguar Club of Central Arizona (USA) – Internet Service Provider, TV & Phone | Sparklight Original Message -----
To: “XK Lovers” xk@jag-lovers.org
Sent: Sunday, December 12, 1999 9:46 PM
Subject: [xk] Alternator Conversion
Since my generator died, I decided to convert to negative ground and an
alternator. I’ll save the generator for future generations. In the
meantime,
has anyone found an alternator which installs easily, without making a new
bracket?
I have found an early 70s American Motors alternator (52 amp) which has
the
correct offset from the back of the front pivot bracket. The only problem
is
that it doesn’t have a built-in regulator, which would simplify things
tremendously since neither the alternator nor the regulator come with
instructions or a wiring diagram.
Thanks in advance,
