In reply to a message from John7 sent Fri 13 Apr 2012:
John
To clarify
‘’ Bronze aluminium’’ or aluminium bronze is not aluminium.
It’s a particular bronze alloy that has presumably some %age
aluminium in it . In the same way that silicon Bronze is not
silicon but like many alloys has a percentage of silicon.
Personally I’ve seen far more pins break than yokes.
What is a worthwhile thing to do is after assembly put a dob of
MIG on the joint between the yoke and the shaft.
This will avoid the situation where there may be say .001’’ of
movement between them which through working gets to be more and
more and the operating of it eventually shears the pin.
This whole problem is why the pins were tapered and the hole in
the shaft needed to be reamed to fit that particular pin.
If you think that is tedious , remember in the 20s Roll Royce
used taper shank bolts[ same amount of taper] and every one was
individually reamed to fit that hole.
If it’s all done properly, by the time the shaft is worn inside
the bushes it will need to be replaced and one can cut it with an
angle grinder to remove it.
The earlier cars and maybe Xks also had a similar pin on the
operating lever outside the bell housing. This had the same
tendency to snap. One did a number of years ago on one of my cars
and I decided to MIG it in situ rather than pull the engine and
gear box out.
As to Rob’s comments about how long the same part had been used
… The 1936 SS parts book the same item … before they started
using C… partr numbers , but rather ‘’ detail numbers’ But one can
x ref the detail number with later SS parts book which provided
both and they were the same. It probably actually predates that to
the sidevalve SS1s.
As I said second hand ones should be available and not overly
expensive
Personally I’d always try MK VII parts people first as Mk VIi
owners are unlikely to pay as much as XK owners
Worcester Classic Spares would be a good start.–
But, the density at least showed that it was not cast
aluminum like the one a very major ‘‘usuals’’ sells. One of
Ed Nantes SS
Melbourne, Australia
