I finally gave in and installed an O2 sensor in my 2 down
tubes (XK120 SE).
Fr the 10th time, motor=xk140MC , newly rebuilt with 9:1
pistons and new cams. I moved my stock xk120 intake/exhaust
system onto this motor.
You’ve already heard ad nauseam that I’ve been struggling
with a lean/rich issue between idle/low speed and high speed
(medium throttle). Plugs are black and quite sooty around
town but light and clean on the highway.
Anyway, I’ve only finished testing the front pipe/carb. Yes
I know there’s a crossover in the intake manifold, and I’m
ignoring that for the moment. The carbs were fitted with
‘‘RC’’ needles and then tuned per the manual. The ignition
system and all is is tuned up per the manual and all seems
to be running correctly other than a slight misfire at very
high rpm (>5000).
Results with RC needle:
IDLE: AF ratio is at 12:1. The pin lift test per the manual
yields the desired up and then down/rough rpm dynamics. Of
course, there’s the question of how much to lift the pin.
Some say a very small amount (1/32’’ to 1/16’’) and others say
lift it all the way up. I lifted it all the way. I then
leaned the idle by 1/4 turn, which brought the ratio up to
around 13.4:1. At this mixture ratio, lifting the pin all
the way up now causes the rpm to immediately fall and the
engine very nearly stalls. Stochiometric is 14.ish:1 . So my
idle is still rich but the pin lift test says ‘‘too lean.’’
LOW SPEED , low to medium throttle(under 2500rpm): AFR stays
pretty much between 10.5:1 and 11.5:1. Interesting to me is
that when I mash the pedal to the floor at 1500rpm, the
mixture goes about 0.5 richer but then leans back out to
about 11.5:1
HIGH SPEED, constant rpm (highway cruising at 3000-3500rpm).
Ratio stays around 11:1. Seems quite rich to me.
WOT (WIDE OPEN THROTTLE) from 1500rpm to 5000rpm. AFR starts
at around 11.5:1 but from 2500rpm to 5000rpm it leans out to
13:1.
I went home and swapped back to my original/old RF needles.
Checked idle and the ratio was still about 13.5:1.
Drove the same route and …
pretty much between 11.5:1 and 12.5:1. Interesting to me is
about 12.5:1. Doesn’t this seem a tad rich?
Ratio stays around 12:1 to 12.5:1. Seems a tad rich to me.
When I went to British Invasion with the RC needles, I was
getting around 15mpg (11:1 ratio). If I could get it to 14:1
I should see a 25% improvement in fuel consumption (creeping
up on Tom Brady and that fat old Mk IX that goes faster than
it should).
WOT (WIDE OPEN THROTTLE) from 1500rpm to 5krpm. AFR starts
at 12:1 and above 2500rpm leans out to 13.8:1.
I will look for a needle that’s leaner at low dash-pot
height and richer as the dashpot goes up. Anyway, I found
all of this pretty interesting…–
John
Boston, MA, United States
