The centrifugal advance springs in my XK distributor are
worn, allowing centrifugal advance to come in much too soon.
Rather than remove/disassemble/reassemble/reinstall the
distributor numerous times while trying various replacement
springs and determining the advance curves with a timing
light on a running engine, a simple advance curve tester can
be made in a few evenings.
It basically comprises a wooden base about 1’ by 2’, having
a variable speed electric drill positioned so its chuck is
pointing up.
In the chuck is mounted a horizontal circular plywood degree
wheel. The degree wheel has an axle in its centre made from
threaded rod, washers and lock nuts. The drill spins the
degree wheel at various rpms. On the top surface of the
degree wheel is a set of degree markings, made by
photocopying a protractor onto white paper.
A Lucas distributor is held by a bracket, so it is
positioned vertically, directly above the centre of the
degree wheel. The drive dog on the bottom of the distributor
shaft engages a wooden piece screwed to the top of the
degree wheel at the centre of the degree wheel. The wooden
piece has a recess carved out to accept the drive dog.
The drill spins the degree wheel which spins the distributor
shaft
A black fixed pointer is arranged to point at the degree
markings on the top of the degree wheel.
An ignition coil and 12v battery are wired up to the dizzy,
forming a primary ignition circuit. Ground the dizzy body
to the battery with a wire and alligator clip. I wired the
dizzy as negative ground, to allow a modern electric
tachometer to be wired in, which indicates engine rpm
Hook up 6 spark plugs by grounding each ground electrode to
the 12v battery, and providing some plug wires leading from
the distributor cap to each plug
Alternately, a single spark plug can be used, receiving its
high voltage directly from the coil; then the distributor
cap, rotor and wires need not be used or even installed
A timing light is wired in, and positioned to shine its
flashing light beam at the degree wheel and fixed pointer.
If you have a setback timing light, most of the degree
markings on the degree wheel are not needed.
Then, to determine centrifugal advance curve, just rotate
the degree wheel slowly ccw by hand until the timing light
flashes. Position the pointer so it points at 0 degrees on
the degree wheel. Then run the drill slowly and the timing
light will flash as the 0 degree mark passes by the pointer.
To determine the centrifugal advance curve, just run the
drill at various speeds, and record the amount of indicated
advance as a function of engine rpm.
To determine the vacuum advance curve, run the drill at a
slow constant speed, and apply vacuum to the vacuum advance
fitting. Record amount of vacuum advance as a function of
vacuum applied
The black pointer is made out of the Guiness can.
http://www.jag-lovers.org/snaps/snap_view.php3?id=1140898172
http://www.jag-lovers.org/snaps/snap_view.php3?id=1140898937--
Gary Grant S818919DN
Ottawa, Canada
