Brian,
Besides advising pin removal by sawing the rusted pin on both sides of
the arm, there has been a lot of discussion a while ago on the “box”
removal as well.
There were some of us advocating breaking the bolts off if it were
impossible to loose them after soaking. The hard part of this effort was
finding the right pair of 6 point wrenches needed to do it. You can’t
“play” with them till they are rounded!
But they will snap cleanly. (That’s what I did).
Unless completely destroyed, the egged hole can be fixed by welding
washers over the hole to correct the wear. It is not “super” critical
and has to render the boxes better than before you removed them.
Mine were so bad that I made boxes from flat stock using a bench vise,
and hammer. I "turned’ the separators from round stock, using a drill
press and mill file.
Build in enough “slop” to eliminate any chances of forcing the mounting
surfaces to flex as the door swings and latches. Regardless of how the
precise 2 boxes are on a test bed, it will near impossible to mount them
in the car with the door hanging on them with the same result. You need
the “slop”.!
Rick
writes:On Sun, 13 Mar 2016 18:23:58 -0500 Brian Ternamian alphajag@att.net
Well, it’s been a couple of really nasty, dirty days that I’ve been
trying to get the bottom hinge out box out. I finally did it, but
don’t remember it being that hard to remove. I had to use all the
bolt head destruction tools in my arsenal that would even remotely
fit into the ridiculously tight areas. Yes, it would have been
easier if I had removed the fender, or at least part of it, but I
didn’t want to ruin any of the lines that might be required to make
another one though I might have to replace the bottom part anyway.
In all this folks have opined how to remove the hinge pin and fix it
and I appreciate all that. Though I never got any advice about how
to remove the hinge boxes which is just as necessary. The lower one
is particularly nasty to get to even trying to destroy all the bolts
and just drift out the remnants.
Also I never got the exact measurement for the center point of the
hinge pin/bolt. I guess after fixing them we all forget what the
critical measurements are. I will be posting an email about how I
finally fixed them though I don’t really know when that will be.
Thanks for all the help and advice so far.
Best regards, Brian
1953 XK120 FHC
Affordable Wireless Plans
Set up is easy. Get online in minutes.
Starting at only $9.95 per month!
